Meaning of the code
Old Feb 25, 2011 | 12:20 PM
8lug's Avatar
Default Meaning of the code
I was checking the code for the abs light which blinked once ( hydraulic pump motor is overrun ) do not know what that is about. And the check engine light has not been on but it blinked a #15 ( ignition output signal ). I just replaced the ignition control module of which I never had a check engine light on when it was misfiring and stalling. Was I supposed to clear the memory of previous codes after the repair or is this a new problem ? How do you clear the codes ?
Old Feb 25, 2011 | 08:38 PM
There should be a 7.5 amp fuse (under hood fuse block) for the ECU. Pull that, give it a few seconds and then put it back-pulling the bat cable should do the same-I just find is easier to pull a fuse than the cable. Once you do that see what, if any, codes come back. Sorry but I'm betting the abs code will come back-low fluid in the abs res? or a leaking o-ring.
Old Feb 26, 2011 | 01:51 AM
8lug's Avatar
Thanks poorman. I cleared the codes and the ABS came back. I will have to top off and bleed the reservoir and see what happens.
tshunnar
Feb 6, 2012 05:54 PM
Stener75
Jul 25, 2010 08:21 PM
thebriz
May 17, 2009 11:42 AM
madsteez
Jan 18, 2009 07:43 PM
TRIGGA
Oct 11, 2006 10:02 PM
