More Problems Again...Emissions
Old Feb 7, 2012 | 06:41 PM
First90AccordMan's Avatar
Default More Problems Again...Emissions
Well I inspected my car before I started working on it and after I Worked on it.
Its a 90 Accord EX with 241K Miles about 500miles on rebuild.
Before:
HC PPM: 15 MPH Limit 125 reading 144
CO%: 15 MPH Limit .50 Reading 6.80
25 MPH Limit .73 Reading 1.12
NO ppm: 25 MPH Limit 1591 Reading 1767
Then After I did rebuild and cleaning up the thing:
CO%: 15 MPH Limit .50 Reading .92
25 MPH Limit .73 Reading .98
NO ppm: 15 MPH Limit 1636 Reading 2277
25 MPH Limit 1591 Reading 2111
Well I have a couple ideas but i want to know what you guys think.
Apparently I have a small exhaust leak, but I have no idea where it is buying some of that exhaust sealer stuff and see what i can do.
Also I have a overheating problem, which i thought was good, but i have no idea if it overheated during the test.
Also, i have replaced filter, o2 sensor, cleaned EGR.
I have three ideas of what parts it could be TPS, MAP or Catalytic converter.
Old Feb 7, 2012 | 07:16 PM
If you haven't cleaned the EGR ports, I would start there. They are almost certainly plugged and will cause high NOX. Check DIY forum for EGR cleanout procedures.
Check PCV valve and hoses carefully for leaks, splits, or blockage.
Check the exhaust by adding some engine cleanout to the running engine and look for smoke at exhaust leaks. Leaks ahead of the O2 sensor might cause excess fuel to be added attempting to balance the fuel/air mixture.
Suggest having a cold cooling system leak test to locate any external leaks. Hopefully, new head gasket is good.
Old Feb 7, 2012 | 07:24 PM
You pulled all of the EGR plugs (5 or 6, can't remember) and cleaned the ports under them?
EDIT: way to slow at typing, I see TX posted....also to correct myself I think the 90 had welded plugs that are a bit different.
Old Feb 9, 2012 | 05:33 PM
I did not do the plugs as i will do those tomorrow. All hoses are good.
Now I did find a exhaust leak after the 02 sensor right before the catalytic converter that someone welded on. I put some brake fluid through intake and cause it to smoke and a lot came out from that area, everywhere else was good.
Can carbon build up cause high Carbon Monoxide? Thanks for the help.
bigb609
Dec 27, 2011 07:18 PM
YeuEmMaiMai
Oct 17, 2006 04:32 AM
thunder_x
Aug 18, 2006 02:48 AM
Jul 24, 2006 03:55 AM
Jun 2, 2006 02:24 AM
