MTF slightly underfilled cause for concern?
Old Apr 23, 2008 | 10:17 PM
crvone's Avatar
Default MTF slightly underfilled cause for concern?
Hi,
So I decided to drain and refillthe Manual Transmission Fluid in may car. Exactly 2 quarts came out, but since I had a hard time getting the new fluid into the refill hole, due to its hard to access place, I was only able to pour in1.8 quarts,the rest of spilled before getting in there!!!
Any way, I only had bought two bottlesof the new fluid and decided to drive the car anyway. It drives fine, and shifting is quite a bit smoother than before.Should I be concerned about MTF being ~ .2 quarts below full?Was planning to do another change in ~ 5K (with the right plastic tube and funnel!)
By the way I used Honda MTF it is pretty thin and has a strong smell,wondering what addetive gives it thisdistinct smell.
Old Apr 23, 2008 | 10:32 PM
Default RE: MTF slightly underfilled cause for concern?
I'd get another quart & fill it. Not too much worry, but I wouldn't go 5000 miles. Then you'll have the rest of that bottle to go along with 2 more you buy after a couple months when you do it again.
How clean was the stuff you drained out? Or why do you want to change it again in 5000?
Old Apr 23, 2008 | 10:49 PM
crvone's Avatar
The old fluid was actually relatively clean, i did see a bit of metal shavings though. That's why I figured I should drain before too long and take another look.
Old Apr 24, 2008 | 12:06 AM
Well, how about drain/fill after a couple days? That way you aren't going all of 5000 with it a little low. Or with a little bit of residual metal shavings...
Old Apr 25, 2008 | 06:46 PM
crvone's Avatar
Thanks, actually I ended up just adding to it (via a syringe!,) until it started to drip out.
Now I got myself a plastic tube that I would feed from top of the engine and use to refill , next time when Idrain the tranny.
nolimitjimmyz
Mar 29, 2013 03:12 PM
j_sparx88
Mar 26, 2013 06:51 PM
maro
Mar 26, 2007 08:39 PM
maro
Feb 2, 2007 12:07 PM
tom15425
Mar 1, 2006 11:49 PM
