My car keeps cutting out on me!
I have a 94 accord ex..when I drive the car for about 3 miles then it cuts out loss all power and the car cuts off can't press the gas and the steering wheel locks up...I've replaced distributor cap and motor and I replaced the main rely..and I'm still havingthe problems can somoody help me please thank u
Originally Posted by Shawboi
(Post 384832)
Do you get a check-engine light anytime? (and does it light up for the 2-second bulb-check when you start?)
There's an "ignitor" inside the distributor (its some kind of isolation-amplifier for the spark signal). Its almost like that thing gets hot after a few miles & quits. I'm guessing that's what the recall was all about. Certainly if it's a recall, you could call any Honda dealer & they can tell by your VIN whether your car is covered & whether it was already done. Another thing is it's not real uncommon to have a flaky ignition switch. The electrical part of the switch gets flaky and it's exactly like you had turned off the key. If you can get the engine to stall by wiggling the key, that nails it. Unfortunately, if it doesn't make it stall, that DOESN'T prove your ignition switch is OK. |
Originally Posted by JimBlake
(Post 384835)
