My car keeps cutting out on me!
Old Apr 12, 2019 | 03:00 PM
Shawboi's Avatar
Default My car keeps cutting out on me!
I have a 94 accord ex..when I drive the car for about 3 miles then it cuts out loss all power and the car cuts off can't press the gas and the steering wheel locks up...I've replaced distributor cap and motor and I replaced the main rely..and I'm still havingthe problems can somoody help me please thank u
Old Apr 12, 2019 | 05:33 PM
hmr's Avatar
hmr
I owned a ' 94 Honda Accord EX sedan with A/T, 4 cyl. That car had a distributor assembly recall. Honda warned that the car could stall in traffic AND that's exactly what happened to me. The car completely shut down on me in traffic ! I was in the left lane on a busy city street with a painted island next to me. Thankfully, I was able to coast into that island and escape collision or we would have been toast. Good luck and be careful !
Old Apr 12, 2019 | 06:34 PM
Do you get a check-engine light anytime? (and does it light up for the 2-second bulb-check when you start?)
There's an "ignitor" inside the distributor (its some kind of isolation-amplifier for the spark signal). Its almost like that thing gets hot after a few miles & quits. I'm guessing that's what the recall was all about. Certainly if it's a recall, you could call any Honda dealer & they can tell by your VIN whether your car is covered & whether it was already done.
Another thing is it's not real uncommon to have a flaky ignition switch. The electrical part of the switch gets flaky and it's exactly like you had turned off the key.
If you can get the engine to stall by wiggling the key, that nails it. Unfortunately, if it doesn't make it stall, that DOESN'T prove your ignition switch is OK.
Old Apr 13, 2019 | 01:43 PM
The Toecutter's Avatar
Also keep in mind the main relay can cut out when it gets too hot. Honda had issues with that on some cars. This led to a lot of people thinking that a main relay is one of the first things to check/replace when having starting/running issues.
rydafolife
Feb 11, 2014 12:38 PM
accordman01
Sep 26, 2011 07:16 PM
moonlight03
Mar 18, 2008 01:36 PM
shostak
Feb 21, 2008 06:58 PM
wisey
Jan 24, 2008 07:02 PM
