My door is stuck
Old Jul 21, 2009 | 10:00 PM
Jmoney's Avatar
Default My door is stuck
I gout out of my car walked into work today. went to leave work and it wouldnt open as if it was still locked i looked at it when i got home everything visible is connected and everything of that sort please help me out here its the driver side too =[
Old Jul 21, 2009 | 10:46 PM
Put your year/model in your signature so we know what car you are driving.
Old Jul 21, 2009 | 11:15 PM
Jmoney's Avatar
sorry 91 accord LX 2 door
Old Jul 22, 2009 | 02:30 PM
The latch could be messed up or the rods on the latch could have been detached.
You will have to partially pull the door panel off to reach in there and feel if anything came apart.
You can drill a hole in the pillar, and use a metal rod to manually release the door. Then replace the door latch.
See: http://techauto.awardspace.com/doorproblem.html
Old Jul 23, 2009 | 08:48 PM
Jmoney's Avatar
i managed to get the panel off completely all the rods are fine so when i drill that hole i just have to try and push a steel peg that will pop it open?
Old Jul 24, 2009 | 02:03 AM
That is my impression. I have never had to do this. Watch the video on that link to see where they drilled and how they did it.
Old Sep 1, 2009 | 04:12 PM
Jmoney's Avatar
so i got the hole drilled i found the l shaped peg pushed it and it moved with force but nothing happened im lost now
Old Sep 1, 2009 | 05:12 PM
I would suggest putting the push rod right on that L shaped peg.
Try a medium/sharp hit on the push rod end with a hammer to get it to unlatch.
Old Sep 2, 2009 | 07:34 PM
Jmoney's Avatar
i did exactly that and the peg just went too far pretty sure i have to drill the striker i mean for a while my door would stick unless i pulled on it hard while opening it so i figure its just demolished somewhere
Arseman03
May 26, 2013 07:38 AM
katzdavi
Aug 28, 2009 07:51 AM
honda99
Mar 3, 2009 10:54 AM
mlydellj
Jul 6, 2006 10:37 AM
tbopha
May 1, 2006 06:06 PM
