Are my fault codes erased...
...if I disconnected the battery?
RE: Are my fault codes erased...
on the 81 accord? i'd think so.
They would be reset. If there is a problem though, they will pop right back up.
Did you repair the issue before you cleared the codes?
If you want the expected way to clear them use a OBD reader to read and then clear the codes...
but as stated, you should fix the issue if it hasn't been corrected or they'll just come back. |
