my idle drops when streering wheel is turned
well yesterday i was at mickey d's and wen i was ordering through the drive trui was turning the steering wheel and it started vibrating and my rpms dropped low? any ideas?
RE: my idle drops when streering wheel is turned
Were you turned all the way in one direction?
not all the way, just enough to make the turn
most likely the power steering pressure switch is failing or has failed.
the ps pressure switch simply informs the pcm that it needs to increase the idle speed because of the ps system load. if it goes bad or the wiring for it breaks and makes intermittent contact it will cause fluctuating idle problems when turning the wheel and it can cause the car to stall when parking or idle speed turning. what year? |
its a 1994 lx auto, well it hasent stalled on me, about how much is this repair? i also noticed at night wen i step on the accel pedal the dash lights dim a bit? any ideas?
Do the rpm also drop when you use the AC or use the window winders, lights etc? If so then I'd be thinking IACV.
Other problem is a bit odd, I'd expect the lights (dash or otherwise) to brighten with increased rpm, which might be a battery issue. |
Mine is affected by any no load, does the same thing turning steering wheel, radio, a/c, high beams only at idle, never stalls i cleaned the iacv and its getting better doesn't do it once it's warmed up. I took off the IACV and cleaned it with throttle body cleaner and it seemed to really help, because before it would shudder and shake.
ORIGINAL: eric123 Mine is affected by any no load, does the same thing turning steering wheel, radio, a/c, high beams only at idle, never stalls i cleaned the iacv and its getting better doesn't do it once it's warmed up. I took off the IACV and cleaned it with throttle body cleaner and it seemed to really help, because before it would shudder and shake. |
ORIGINAL: eric123 Mine is affected by any load, does the same thing turning steering wheel, radio, a/c, high beams only at idle, never stalls i cleaned the iacv and its getting better doesn't do it once it's warmed up. |
That's the thing when I first got the car the only one I could notice was the steering. But then after I made that post it started doing it worse for the steering and for everything else. Now it just does it lightly for the steering, but doesn't shudder or stall.
