Need 91 wagon wiring help!
Old Mar 27, 2006 | 07:40 PM
45auto
Default Need 91 wagon wiring help!
Hello all,
I have a 1991 Accord wagon with power door locks. The power door lock computer underneath the drivers seat got wet in hurricane Katrina (the transmission and engine computers also died in the storm, replaced those off Ebay and everything is working fine there!). I have a new lock computer, but some of the wires corroded off the plastic connector that plugs into the computer. The factory service manual does not list the order of the wires into the connector. Could someone please look at their connector and send me a list of the wire colors as they go into the connector, from top left to bottom right as seen from the side of the connector that the wires go into?
Thanks,
Keith
45auto@softhome.net
Old Mar 27, 2006 | 09:15 PM
lightshow's Avatar
Default RE: Need 91 wagon wiring help!
ha i have a 91 wagon too. do you have to take the seat out to get to it?
Old Mar 27, 2006 | 09:18 PM
lightshow's Avatar
i guess it wouldnt be a bad idea anyway. my drivers seat only moves like 4 inches because of all the damn coins that have fallen into the tracks lol
Old Mar 27, 2006 | 10:33 PM
45auto
Hi, thanks for the quick reply!
You don't have to take the seat out, just slide it all the way back. There is a plastic cover on the floor in front held down by a 6mm bolt (10mm head), then the computer is held down by another 6mm bolt under the plastic cover. The connectors plug into the driver's side of the computer. There are 2 connectors held in by the typical plastic squeeze tabs. My little one has one broken wire and I can see where it came from. The big one has 3 broken wires which I can't figure out which holes they go to:
Green / Blue stripe, Green / white stripe, and solid white.
I've attached a .jpg below of the connector and the wires still connected to it.
If you could tell me which wires go into the EMPTY holes it would be greatly appreciated!
[IMG]local://upfiles/3422/F1100DCADE4041ACB2CA1D7855B68476.jpg[/IMG]
daver1100
May 8, 2014 02:41 PM
Boser1995
Feb 1, 2011 04:55 PM
96fseries
Mar 15, 2008 07:19 AM
45auto
Apr 10, 2006 05:06 PM
ryan ortego
May 19, 2005 06:06 PM
