need help
hi i have a 96 accord that the motor is bad im not sure if its is a lx or dx but i know its a non vtec but besides that i was wondering if a 94 motor would fit in my 96 and i have all the set up for the obd2 for the 96
it will not work
It does not work
it is not the right motor
You cannot use a 98
However if you think you can just make sure you get the full harness, ECU, steering column, and factory key with chip in it.
Have fun installing a 98 steering column in your 5th gen Honda. If you do not use the steering column then the motor will not start as the ECU has an imobilizer in it. If you look around you will not find any 6th gen motors in 5th gen cars cause it is just too much work.
You need a 94-97 motor
You may be able to use a 90-93 but you will have to swap over a lot of stuff from your old motor to the new one.
