need help with 91 accord
ok earlier today i was driving my car and then it started slowing down and i tried pushing on the gas to make it go and it wouldn't go anymore then i turned it off and now it won't start. so if anyone have any suggestions please let me know.
91 honda accord se
91 honda accord se
First thing, check your ignition fuse. That is the most likely cause. If that is ok, see if you are getting fire to the Positive terminal to the coil and distributor. If that is ok, check the coil with an ohmmeter for resistence. If there is none, replace coil. If there is resistence, replace distributor. Also check grounds as well. Not likely to have a bad ground, but somewhat possible.
Anymore questions, feel free to contact me
dachoka@aeg1.net
dachoka@aeg1.net
99 percent it is because of improper installation.
Let us know if you know where to find the ignition fuse - on american junk its on the back side of the motor - it's a Mega fuse most of the time for 175Amp.
I have to check the diagram for your car though.
Evlampius...
What did you find out for this member, he's more than likely waiting for you to continue to give him that correct answer you were going to get for him about that diagram on his car..
Please respond for him and the rest of us in case we run into the same problem..
Thanks From Us All In Advance...
WheelBrokerAng...[sm=gobble.gif]
ORIGINAL: Evlampius
99accordf23a5
May 6, 2014 12:51 AM
Levibyz
May 31, 2011 09:43 PM
