need help asap!
i got a 1992 honda accord , she runs good while cold but starts to bogg when she gets warm or when i feed it gas she idles wicket around 200 rpm always did. its a 5 speed but i was driving it the other day and she ran perfect took it later that day and she started to bogg when i gave it gas i changed the plugs wires and dist checked every hose for a air leak and there was nothing i put sea salt in it because i was told it would help but id tap the fuel rail and shed pick up any ideas here is it my fuel line or is it getting to much air or is it not getting enough gas?
it was on but when i changed the plugs and that it went out, and i put the sea salt in the gastank like it said to do and i called a buddeh of mine to see if he had any idea and he said hes cavi did the same thing and hes oxgen sinsor was gone but i cant see it being gone and doing what its doing ?
You can check the codes yourself, just need a piece of wire to jump the service connector.
See this:
https://www.hondaaccordforum.com/for...threads-40780/
In that thread you will see this:
https://www.hondaaccordforum.com/for...l-codes-35962/
Codes will store until reset. So if the light was on and nothing has been done to clear them, they are still there.
Get the code - it "sounds" like you have a code 43
but that is a guess.
See this:
