Need help what is this
Old Aug 3, 2013 | 07:20 PM
glenn2000's Avatar
Default Need help what is this
I had a squirrel under my daughters 2003 accord hood and this was on the ground can anyone tell me what it goes too. It is rubber not plastic. Thanks in advance I know some of you car guys will know this. Glenn
http://i897.photobucket.com/albums/a...ps6f9d5f79.jpg
http://i897.photobucket.com/albums/a...ps8b9e781b.jpg
http://i897.photobucket.com/albums/a...ps017a6bc8.jpg
Old Aug 3, 2013 | 07:32 PM
Is this a 4 or 6 cylinder?
Old Aug 3, 2013 | 07:47 PM
glenn2000's Avatar
It is a 4 cylinder
Old Aug 3, 2013 | 08:04 PM
This might take some searching. It kind of looks familiar; but, I haven't found it yet.
Old Aug 3, 2013 | 08:37 PM
I combed through most of of my available sources and I couldn't find anything for the 2004 Accord 4 cylinder exactly like that.
Does the car start?
In addition, is the Malfunction Indicator Light (MIL) aka Check Engine Light on?
Old Aug 3, 2013 | 09:37 PM
glenn2000's Avatar
it started up fine but has not been driven yet no check engine light either so far.
Old Aug 3, 2013 | 09:52 PM
I looked through practically every sensor and electrical connector listed for her car, which includes actual pictures, location, etc. and I didn't find anything like that. The sources I checked are pretty extensive.
I was thinking that if it didn't start or there was a trouble code, then it might narrow down the area.
I am starting to wonder whether the squirrel got it from a nearby car and took it where your daughter's car was; kind of like them storing nuts, etc.
Old Aug 4, 2013 | 03:54 AM
glenn2000's Avatar
I understand but we live on 40 acres no other house within squirrel distance there was also some insulation right were that was laying that made me believe it happened then, I guess the only other car that had been out there the day before but not in the same spot was a 04 ford f150 fx4 super cab. Will keep you posted if a problem shows up. The fate of this squirrel is also going to change soon as this is not a good place to have one wanting to chew things up.
Old Aug 4, 2013 | 09:55 AM
A good squirrel hunt..in more than one way..cool
To me that looks more like a "cap" of sorts (trans vent or something like that but then the "arrow" with the "F" has me second guessing myself) - I added a red arrow (hard to see-sorry), is that solid or is there a "hole" like a wire would fit thru?
Old Aug 4, 2013 | 10:10 AM
brockj's Avatar
When i saw 2nd pic instanly thought of dust cap for bleeder valve. Look long compared to diameter. Can you scale it in a pic, for better reference?
