Need to identify part that broke off of solenoid
2 Attachment(s)
Hi, while removing the VTEC solenoid to inspect the gaskets, I noticed the plastic part that sticks out of the side had broken off, with most of it stuck in a green connector (attached to wiring).
The broken part looks like it would be #13 in this diagram: https://www.hondaaccordforum.com/for...ine=1477708286 In the photo below, it's the red circled area. The purple dotted line indicates approximately where it broke off. https://www.hondaaccordforum.com/for...ine=1477708286 What is that part called, and is there a replacement part number I can look up? I've seen conflicting info and could use some clarification. Will a standard wrench remove the bolt from the solenoid assembly, or do I need a special tool? Does this part typically break like that? |
Vtec Oil pressure switch. Part number 37250-P07-003.
A site like hondapartsnow.com lists the OEM part numbers. Double check that I didn't mess up entering your vehicle info on that site. |
Thank you, that does appear to be compatible.
