Need to identify part that broke off of solenoid
Old Oct 28, 2016 | 09:31 PM
kpoof's Avatar
Default Need to identify part that broke off of solenoid
Hi, while removing the VTEC solenoid to inspect the gaskets, I noticed the plastic part that sticks out of the side had broken off, with most of it stuck in a green connector (attached to wiring).
The broken part looks like it would be #13 in this diagram:
In the photo below, it's the red circled area. The purple dotted line indicates approximately where it broke off.
What is that part called, and is there a replacement part number I can look up? I've seen conflicting info and could use some clarification.
Will a standard wrench remove the bolt from the solenoid assembly, or do I need a special tool?
Does this part typically break like that?
Old Oct 28, 2016 | 09:41 PM
Vtec Oil pressure switch. Part number 37250-P07-003.
A site like hondapartsnow.com lists the OEM part numbers. Double check that I didn't mess up entering your vehicle info on that site.
Old Oct 28, 2016 | 09:58 PM
kpoof's Avatar
Thank you, that does appear to be compatible.
rolly24
Dec 28, 2012 10:24 AM
g22cd5
Nov 5, 2010 01:29 AM
renegade05
Aug 8, 2010 12:01 AM
atsioukl
Jul 8, 2010 01:37 PM
klrspz
Mar 13, 2008 09:03 AM
