Need to identify part that broke off of solenoid
Hi, while removing the VTEC solenoid to inspect the gaskets, I noticed the plastic part that sticks out of the side had broken off, with most of it stuck in a green connector (attached to wiring).
The broken part looks like it would be #13 in this diagram:
In the photo below, it's the red circled area. The purple dotted line indicates approximately where it broke off.
What is that part called, and is there a replacement part number I can look up? I've seen conflicting info and could use some clarification.
Will a standard wrench remove the bolt from the solenoid assembly, or do I need a special tool?
Does this part typically break like that?
