Need info on honda I want to buy
Old Aug 30, 2008 | 04:07 PM
bigdawgdan
Default Need info on honda I want to buy
Hi,
I'm a newbe to Honda. I'm looking at a used 95 accord w/ 175K miles. I always heard foreign cars can go 250K with ease. Is this high for a Honda? They are asking $2500. It is in great shape except the mileage and a few rust spots from salt.
Any help would be great.
DG
Old Aug 30, 2008 | 05:06 PM
ford's Avatar
Default RE: Need info on honda I want to buy
i think it is still a good deal..although i would wanna fix the rust spots when i get it..so it wouldnt get worse..yeah..hondas lasts...as well as most japanese cars last...but you know it also really depends on the owner...if the owner really takes good care of the car...
Old Aug 30, 2008 | 05:19 PM
if it was taken care of it should be good to go, i'll say thats somewhat high for mileage, i mean i've seen some accords with 500+k on them.
Old Aug 30, 2008 | 07:30 PM
bigdawgdan
What about the salt getting into the engine compartment and rusting out motor mounts and other metal things. Or the gas tank etc?
DG
Old Aug 30, 2008 | 08:30 PM
The motor mounts are rubber bushings, so salt will not rust them out. Plus the splash shields will prevent salt and water from getting up there. You can see the front mount, and you should check that it is in good shap.
The gas tank has a plastic guard protecting it, so the gas tank shouldn't rust.
The timing belt is due at 180K miles on a normal schedule, so find out when it was last done. It needs to be changed every 6 years or 90K miles. That job typically costs ~$600. You might get them lower the price to offset the maintenance work.
You should take the car to a shop that specializes in hondas to get a used car inspected. If they find something that needs fixed, you might be able to get the price lowered too.
Old Aug 30, 2008 | 08:40 PM
bigdawgdan
Thanks ya'll. This might be a keeper. Going for the test drive in the morning.
DG
Old Aug 30, 2008 | 11:00 PM
ford's Avatar
cool...good luck on that...keep us posted on like how the car run and stuff...
Levibyz
May 27, 2011 10:46 PM
frezel
May 14, 2011 08:11 PM
jdelgado
Oct 29, 2007 09:49 PM
