Need Opinions
Old Jul 8, 2007 | 09:06 PM
Accord94's Avatar
Default Need Opinions
Ok i am wanting to do alot to my accord, but im not going to have the money to do it all at one, what do you guys think i should start with and then go to, like make me a list of first to last if you dont mind.
Old Jul 8, 2007 | 09:15 PM
BlkCurrantKord's Avatar
Default RE: Need Opinions
Decide for yourself how you'd like your car to perform, look, handle is where I'd start first. Then start from the ground up.
Old Jul 8, 2007 | 09:29 PM
Accord94's Avatar
i know how id like it to look and perform i just dont know where i should start, should i leave it maroon or paint it?
Old Jul 9, 2007 | 10:43 AM
00AccordLX5spd's Avatar
Registered User
When was the last time the timing belt was changed? You may want to start there.
Old Jul 9, 2007 | 12:15 PM
Accord94's Avatar
im not sure, is it hard to change or can i do it myself?
Old Jul 9, 2007 | 12:43 PM
Dazed's Avatar
It all depends on wat you want ur car to do...
I say timing belts, i think it is very hard to do on ur own and also expensive, but important.
With my car, i started off with an oil change, i think my gas caps were replaced, and then sound.
And just today my spark plugs were replaced and SRI installed.
Next for me is brakes and timing belt.
Its all a matter of choice, and sometimes budget.
Old Jul 9, 2007 | 08:14 PM
Accord94's Avatar
yea the oil had been changed right before i bought the car, its got a CAI, new brakes, installed amp kit today and borrowing my buddies old system till i get money to buy my own, i guess ill do spark plugs and wires next?
Old Jul 10, 2007 | 07:06 AM
03Sleeper's Avatar
Spark plugs would work wonders for 6th and lower gen. (Yours is 5th). Looks good and increases throttle response.
Old Jul 10, 2007 | 02:38 PM
Registered User
T-belt is pretty complicated. I personally would not do that myself. There is a write up on it in the DIY section. Go there and check it out for yourself. Whip out the Yellow Pages & call a few Honda-certified shops and get a price quote. You might as well have the water pump, balance belts, & oil seals changed while they are changing the timing belt too. I hate to be the bearer of bad news, but the service will cost you anywhere from $400 to $800.
The timing belt is one of the most crucial parts of your engine.On your model, it is supposed to be changed every 90,000 miles. If it breaks, the engine is toast. I would start there before investing in any mods.
Old Jul 10, 2007 | 02:51 PM
sir_nasty's Avatar
^^I don't want to agree but I have to... do you know if the previous owner had it regularly serviced at one particular shop? If so then call them and ask if you can get a copy of the service records, if you can then you'll know if you need to fix it or not but putting a bunch of money into a car and making it nice just to have the engine blow because of a lack of maintence would not be fun...
I had a 94 civic with a Grade A VIS carbon fiber hood, aftermarket bumper, fenders, headlights and mirrors to install, strut tower bars, AEM V2 Intake and H&R Cup kit suspension, then the motor hydrolocked with some snow and blew the rings... sucked down a quart every 2-3 days.... basically, speaking from experience make the car run well before you invest your money...
LouieHonda
Jan 3, 2007 07:40 PM
VT zog
Jun 19, 2006 05:34 PM
dneunzig
Jun 7, 2006 11:12 PM
thunder_x
May 5, 2006 01:01 PM
OBRIEN78
Feb 27, 2006 09:42 PM
