need some help with sensors
i have a 01 accord coupe V6
hey guys ive been looking around through the threads and havent been able to find a DIY for idle air control valve sensor and a DIY for the EGR valve sensor. my car seems shaky and ive been reading around that it can be these 2 sensors and need some help could use some feedback and thanks guys. |
There is a service bulletin on how to clean the EGR ports on a V6. Google A99-085.pdf to see the procedure.
Replace any maintenance items are due to be changed, like spark plugs, air filter, etc. Usually when a the IAC valve or the EGR valve has a problem, the check engine light will tun on. If it does turn on while driving, stop by an autozone and have them read the code(s) and post the code number on here. It will start with the letter P and have four numbers, ie P1234. |
thanks for advice dude and will do. ill keep you guys updated.
