need some help with sensors
Old Feb 8, 2010 | 05:47 PM
cloud0084's Avatar
Default need some help with sensors
i have a 01 accord coupe V6
hey guys ive been looking around through the threads and havent been able to find a DIY for idle air control valve sensor and a DIY for the EGR valve sensor.
my car seems shaky and ive been reading around that it can be these 2 sensors and need some help could use some feedback and thanks guys.
Old Feb 8, 2010 | 07:00 PM
There is a service bulletin on how to clean the EGR ports on a V6. Google A99-085.pdf to see the procedure.
Replace any maintenance items are due to be changed, like spark plugs, air filter, etc.
Usually when a the IAC valve or the EGR valve has a problem, the check engine light will tun on. If it does turn on while driving, stop by an autozone and have them read the code(s) and post the code number on here. It will start with the letter P and have four numbers, ie P1234.
Old Feb 8, 2010 | 07:32 PM
cloud0084's Avatar
thanks for advice dude and will do. ill keep you guys updated.
timaccord
Aug 17, 2011 05:12 PM
miks
Apr 25, 2007 10:38 AM
DMN_RITE
Apr 20, 2007 03:27 AM
enerlevel
Sep 5, 2005 02:26 AM
Rasher
May 17, 2005 01:19 AM
