Need urgent help!!
Old Apr 18, 2012 | 05:48 PM
ezhead3's Avatar
Default Need urgent help!!
My car is a 2002 with >205k miles on it. For the most part it's still running very well but it's starting to act funny. It idles low which shakes the engine which thereby shakes the car. Mind you, the shakes aren't like tremors or anything but with them being associated with the low idle I'm concerned. I was originally thinking it might be either bad gas or the idle control valve. I'm not sure though. Any suggestions?
Old Apr 19, 2012 | 01:24 AM
Cody_754's Avatar
Almost A Senior Member
Sorry, don't think I can really help with your problem, but welcome to the site! I would google around if I were you and see if there's anyone else with similar problems.
Old Apr 19, 2012 | 11:47 AM
Set your base idle. There's a thread in the DIY section about that.
Is it 4-cyl? V-6? Automatic trans?
Old Apr 19, 2012 | 03:27 PM
Hello New One..Welcome..as you can see..HELP goes in the help threads..
Old Apr 20, 2012 | 12:43 PM
ezhead3's Avatar
It's a 4 cyl 5 spd
Old Apr 20, 2012 | 03:07 PM
When were the spark plugs last changed? Did you use the NGK plugs recommended by honda?
Does your 02 have a distributor, or is it a coil-over-plug setup?
99accordf23a5
May 6, 2014 12:51 AM
kingestell
Aug 30, 2013 12:43 AM
95_Honda_Accord_Ex_Sedan
Feb 17, 2013 08:28 PM
hallacam
Jan 30, 2010 08:42 PM
kysit
Nov 25, 2007 05:44 PM
