New headlights installed
Old Sep 21, 2008 | 09:13 PM
dxception
Default New headlights installed
Hello,
I'm new to the family here. I have a '98 Accord Lxi. Just put in some led halo headlights. Everything is working beautifully. I powered the halo's and led's with the parking light wires. One problem. It doesn't have anything to do with the new headlights. The passenger side turn signal doesn't light up unless the the turn signal is activated. The driver side turn signal bulb lights up when the parking lights and headlights are on as well as when the turn signal is activated. Has anyone else run into this problem or know of any quick fixes. The bulbs are brand new and the old bulbs had the same issue.
Thanks in advance for any help. Again the bulbs are not the issue. I have switched them back and forth to make sure.
Old Sep 22, 2008 | 10:31 PM
dxception
Default RE: New headlights installed
On the 1998 Honda accord, do theturn signal/corner/side markerlightsstay on when you turn on the parking lights and regular lights and then blink when you signal?
Someone please respond.
Thanks
Old Sep 23, 2008 | 11:20 AM
Fenix's Avatar
i had a similar problem with tail lights. the right blinker didnt blink till i hit the brakes. Strange thing is that the problem only occured when the headlights are on. if the lights are off the blinker works fine. i solved the problem by not using my blinker. But now it solved itself. Strange :?
Old Sep 23, 2008 | 11:38 AM
finch13's Avatar
To answer your question about the 98 accord, yes. Just as you described it.
Pilot Mobbin
Jan 30, 2013 07:18 AM
brownn74
Dec 19, 2012 08:12 AM
steviebix
Jan 3, 2008 02:13 AM
otsb708
Feb 22, 2007 03:34 AM
