new owner of 93 honda accord
Old Nov 14, 2011 | 04:52 PM
93 honda owner first time's Avatar
Question new owner of 93 honda accord
So this is my first post and i need help. I have a 93 honda accord lx and there is a 4 way sound like the flashers are flashing but there not. Can anyone help me and tell me what it is and where it may be located at. Thanks
Old Nov 14, 2011 | 05:12 PM
k24acura's Avatar
More details. Do the flashers work?
Old Nov 14, 2011 | 05:40 PM
Default not real sure
right now i couldnt tell ya. ive only had the car about a day and the lower ball joint broke so my uncle is working on it right now so ill have to get back to you on that one.
Old Nov 15, 2011 | 12:55 AM
Ya! get back with us after your uncle checks it out...maybe he will find out that problem for you also..
Old Nov 16, 2011 | 08:36 AM
ok the four way flashers does work.
Old Nov 16, 2011 | 08:54 PM
Once the car is back, ball joint and that fixed.....let us know and we can go from there.
Old Nov 20, 2011 | 02:31 PM
Default car is back
ok the flashers and turn signals all work. Found out the battery is bad if that helps. Still, when car is shut off you still here the ticking noise that sounds like the flashers are on.
Old Nov 21, 2011 | 12:26 AM
If the sound is coming from the flasher relay, then the relay could be bad. The hazard switch could be bad. The turn signal switch shouldn't work when the car is turned off, so I would suspect that last.
Old Nov 21, 2011 | 09:25 AM
k24acura's Avatar
Is there a security system?
Old Nov 24, 2011 | 04:29 PM
no security system.
