New P0796 Code
I have a 2013 Honda Accord EXL 4 cylinder cvt transmission and it gives this code P0796 and it slows down to about 40 miles per hour and I pill over and turn the vehicle off for a few minutes and I restart it and it drives normal. Which sensor do I need to buy and fix this problem.
DTC P0796:Pressure Control Solenoid Valve "C" Performance or Stuck OFF (Engine Type: K24W1)
CVT CLUTCH PRESSURE CONTROL SOLENOID VALVE TEST (CVT) Replacement requires removal of the CVT valve bodies. Looks like the part is #17. https://cimg2.ibsrv.net/gimg/www.hon...ec4ea2189a.png |
The pressure control solenoid C on the transmission is stuck off. This doesn't necessarily mean the sensor is bad. The problem can be the sensor, the electrical connection to the sensor, the wiring, or the PCM.
Thanks so much for letting me know this
I appreciate this information very much.
Originally Posted by CMOGI23
(Post 399941)
| All times are GMT -5. The time now is 07:35 AM. |
