new pads and rotors up front
Old Sep 14, 2008 | 10:57 PM
travelhondaman21
Default new pads and rotors up front
i am installing new brake pads and rotors up front on my 97 accord, 4cylinder, non v-tech. and i was wandering what is the correct brake in procedure so that the rotors do not warp. the brake pads are semi-metallic and the rotors are the ones from autozone. thanks.
Old Sep 14, 2008 | 11:23 PM
blinkz0rz's Avatar
Default RE: new pads and rotors up front
Uh, dont be dumb? There really isnt any brake-in period for brakes, it just takes careful precise driving to make sure nothings gets screwed up where you have to change them again.
Old Sep 15, 2008 | 09:41 AM
falkore24's Avatar
Find a good long block that you can drive around a bunch of times without other cars getting in the way. Don't fully stop ever during this proceedure .... if you have to, slow down early and coast in neutral to a stop, but don't stop with the new rotors (for front rotors, you can use the E-brake if needed). Speed up to 30 mph and brake moderately to 10-15 mph, speed up to 30 and do it again. Do this 10 times. Now speed up to 45 and do the same thing with hard braking down to 10-15 mph, 10 times. Turn around and do the first braking procedure 10 times going the other way around the block. Done.
If you want to take it a step further, wet sand the rotor braking surfaces with 1200-1500 grit paper prior to installation.
johnavh
Aug 6, 2012 08:28 PM
RickESMD
Jun 21, 2012 06:19 AM
Tippman7641
Jan 26, 2009 12:47 PM
nhford
Mar 1, 2008 08:35 AM
Jan 16, 2007 01:46 PM
