new to site need help bad have tryed a bunch of stuff
Old Oct 2, 2010 | 10:01 AM
jeremyshane420's Avatar
Default new to site need help bad have tryed a bunch of stuff
i have a 96 accord with a 2.2 me and a buddy was running the power wire for my amp and moved the fuse box under the hood to run the wire through the fire wall put everything back and went to go for drive around the block and now car has no power and when u give it gas the rpm wont go past 3000 rpm it acts like the rev limiter kicks in. I have hooked it up to our computer at work and it says the the crank position sensors are bad so take those out clean em put em back does same thing put brand new ones in and still does the same thing, i have looked at all the wires in the fuse block unplugged all the sensors to make sure everything was plugged in i have took the ecm fuse out to reset the ecu unhooked battery ive done everything i can think of to fix my problem im running out of ideas could someone please help me
Old Oct 8, 2010 | 06:48 AM
come on guys and girls please help me i need some ideas on what to do about my car. it has me stumped ive tryed everything
Old Oct 8, 2010 | 07:39 AM
What's the actual error code number?
Old Oct 8, 2010 | 11:41 AM
theres 3 numbers p0335 p0135 and p0141
Old Oct 8, 2010 | 11:52 PM
hondadude's Avatar
Recheck the work done around the connectors at the top of the passenger side strut tower.
You might want to unplug them and replug them.....Key off of course.
Old Oct 9, 2010 | 07:41 PM
P0335 = crankshaft position sensor low input
P0135 = primary O2 sensor heater circuit
P0141 = secondary O2 sensor heater circuit
Check the wiring like HondaDude said. Also look for damaged insulation, cut through somewhere in that wiring.
Old Oct 10, 2010 | 11:52 PM
ok the guy at advanced said that half my crank sensor was working so is there any certain color wire i should look for ive had thay area of the car tore apart a few times and didnt see anything noticeable
Old Oct 14, 2010 | 08:44 AM
Ok I've checked all the wires and all the plug ins and everything seems fine. Anybody else Have any ideas
Old Dec 31, 2010 | 06:14 PM
trickett's Avatar
I bought this car from Jeremy. Ive checked the resistance on the crank sensor and looked at the wiring between the sensor connector and the connectors by the right side strut tower, and there are some wires with stripped insulation. Ive been working with it trying to get it to come out of this trouble but nothing so far. Will I have to replace this wiring harness? Any other suggestions?
Old Dec 31, 2010 | 06:46 PM
Those wires go to the ECU. I would unplug the ECU and measure the resistance across the proper ECU pins. That would verify a wiring problem.
For the crankshaft, the connector is the 31-pin C connector. Measure the resistance between Pins C2 and C12. It should match the resistance at the actual sensor.
The O2 sensors are on the 32-pin A connector. Measure the resistance again. It should be identical for the resistance reading at the sensors.
Primary is A5 to A10. Secondary is A6 to A10.
Make sure the sensors are plugged in.
