newb with question
Hi All. I have a question for you. My 2000 Accord is giving a code P 1457. I have researched and found the most obvious answers.
Here"s my question. I damaged the black box under the passengers side fender (not sure what it is called) attaches to the air filter intake. There is a small hole in it. Would this give me the code? I also checked the gas cap and it is OK. Any comments would be greatly appreciated. Thanks from the new guy.:) |
Welcome.
4-cyl or V-6? They might as well be completely different cars... What were the "most obvious" answers that you found? What did you do to check them & rule them out? That black thing at the front fender is just a resonator for the intake air, it will not set off that code. P1457 = EVAP system leak - canister part of the EVAP system The EVAP canister lives underneath the car, below the left-rear seat. Find it by looking under the rocker panel just forward of the left-rear tire. Check out this post over in the DIY section. https://www.hondaaccordforum.com/for...ad.php?t=27179 |
