Next ABS question
Old Apr 2, 2011 | 11:32 PM
Wiley-X's Avatar
Default Next ABS question
Again with the 94 Accord. Is the ABS system two wheel or four wheel? If two, I'm guess that it is the front two.
How would I identify the bad sensor?
Also where can I find them for $50 as described in the reply to my other post? I checked a couple online sources and they were closer to $150.
Also, if all else fails, is there an easy way to remove the instrument cluster?
Thanks for the quick response to the other question.
Old Apr 3, 2011 | 09:38 AM
System is 4-wheel. You need to extract the error code/s by shorting service check connector under glove box, turning keyswitch On, and reading flashes (all short flashes). Code 4-1 = ffff-f. There is a single long (2-sec) flash first to show the ABS bulb light is good. W/ error code the fault can be determined and system restored.
Check ebay or car-part.com for wheel sensors (used and new). I may have been wrong about wheel sensor cost, but I've bought modulator pumps through car-part.com for $35. Wheel sensor will require some calls to local salvage yards to locate. Car-part does not have the wheel sensor as a listed item.
You don't know it's a wheel sensor so get the codes first. Even if wheel sensor code is presented, the sensor may be OK. Clean sensor by removing and polishing sensor, then stuff a rag down the sensor hole and turn wheel to polish ABS tone ring on the CV axle or rear axle. Dirt/grease can degrade the signal from the sensor.
Old Apr 3, 2011 | 11:58 AM
Old Honda Dude's Avatar
Default Abs
When you start the engine do you hear the ABS solenoids run. This should only happen for a few seconds. If you hear the ABS pump run for a longer time every time you start the car you may have a leaking actuator in the module. check for leaks at modulator. I believe there are three solenoids in the modulator . Some years these can be replaced. there are two for the front wheels and one for the rears..You may find the procedure in the DIY section. Good luck.
93Accord2.2
Nov 7, 2013 07:10 AM
poff1986
Aug 13, 2006 02:04 AM
turbotone
May 23, 2006 02:18 PM
HAcc407
Mar 8, 2006 11:41 AM
