NGK Iridium Spark Plug Installation
I'm in the process of installing NGK Iridium IX Spark Plugs. I have a few questions:
Are my spark plugs pre-gapped? If they aren't, what gap measurement should I use? I've checked my manual, it says 0.4 inches, but I was wondering if it would be any different for aftermarket plugs.
There's also one plug I'm having difficulty getting to, I'm thinking about just having a shop install the last one. Will I run into any trouble with 5 new spark plugs and 1 old plug?
Gap should be same for OEM and equivalent aftermarket plugs. I believe that all platinum tips are pre-gapped, but check NGK website or check the plug gap to be sure.
No problem w/ 5 new and one old plug until shop can replace last plug. Maybe time to purchase some wobbly extensions and spring-supported univeral. This will usuallyallow access, unless it's necessary to get under the vehicle w/ a lift to access.
The auto parts store always tells me they're pre-gapped and I can throw them in but when I check them with a feeler gauge they're usually at .8mm instead of 1.1mm
Yea sorry about that, I was just trying to remember off the top of my head. It is in fact .44 inches.
I already have one of those swivel spring spark plug wrenches, and I still couldn't get to the last plug. I have a friend that owns a shop in New Jersey (where I am headed next week), and he's going to take care of the last plug for me.
ORIGINAL: coup de grace
How can you not get the last one out? Is it just location or tightness of it? If you need a little extra elbow room you can tilt the hood back against the windshield with a rag underneath it, granted it's just on hinges and not struts.
ORIGINAL: falkore24
Finch: It's a V6. The rear 3 can be a PITA.
The fact that they're so difficult to get out leads me to believe they were put in too tight in the first place...
