No brakes lights working
Old Apr 20, 2007 | 03:32 PM
razzle00
Default No brakes lights working
Hi,
I have a 2002 Honda Accord and the left and right main brake light stopped working. However, the brake light on the spoiler and in the back window do still work. Is there a fuse I could check that would cause this to not work? I checked the manual for the fuse, but there is no specific fuse for the brake lights. It must be ona fuse with something else. Can anyone tell me which fuseI would check for the brake lights?
Thanks,
Razzle
Old Apr 20, 2007 | 03:36 PM
Shadow1992's Avatar
Default RE: No brakes lights working
Most brake light systems use multiple fuses, so if one goes at least some of the ligths work. CHeck both fuse boxes for any blown fuses, shouldn't take more than a few minutes. Unfortunately I don't know enough about that year to give a more detailed description for you.
Old Apr 20, 2007 | 04:07 PM
deserthonda's Avatar
chk fuse # 9 7.5 amps driver's under dash fuse box, if fuse is ok it could be a bad brake light failure sensor .. or bad bulbs or bad wiring ( poor connection )
csh217
Apr 30, 2013 09:03 PM
Uberpippi
Feb 1, 2013 10:09 PM
naimperez
Oct 2, 2011 07:01 PM
rogerthat23
Apr 11, 2009 10:32 PM
arunsam3000
Mar 6, 2007 01:40 PM
