NO A/C 95 v6 Accord PLEASE HELP
Ok so I have a 95 V6 Accord with about 250k miles. The A/C was acting up last summer, the clutch wouldnt kick on at all, I hit it a few times and it started working, go figure.
This year, after Ive tried hitting it good a few more times, it cease to live
By the way, I use this as a work vehicle to deliver stuff and its horrible during the hot humid Charlotte days!
So my question is, does anyone have any info on how I can replace my A/C system and make it like new again? I do not want to pay a shop for the labor when it shouldnt be THAT hard... Any help is appreciated!
if you hit the clutch and it started to work the clutch gap is too wide ,,
did it cool ok when a/c was working ?? if so first thing i would do is to chk the clutch gap and adjust it..if too wide ......
I havent done a ac pressure switch reading yet, how do I do that?
The A/C worked for about 2 months and then I stopped using it but it was working fine when it kicked on.
Really sounds like the gap is out.....The pressure switch, only played with the 4 cyl version of these. Follow the high side line, small on-or the charge port should have an "H" on it...look for a switch with two wires going into it...on the 4 cyl it is under thae battery...you have a 6, so not sure where.
When you turn on the a/c, do both fans turn on when the engine is running?
Also, unplug the compressor. Start car and turn on a/c. Check that you have 12V going to the one wire going to the compressor to ground. I use a valve cover bolt for a good ground.
Let us know what you find.
You need a volt meter. You need to set it to read DC voltage. Depending on the volt meter, the scale should be set to 20. That means it will read accurately 2-20 volts. Make sure you volt meter is working by testing voltage across the posts of the battery terminals. Red meter lead to + post, black meter lead to - post. If you read around 12V, you know your meter is working properly.
Now for the electrical connector, it is a one wire connector. Unplug the connector. Touch the red lead to the wire that is now not connected to the compressor. Touch the black lead to a valve cover bolt. See what the meter reads. Make sure the red volt meter lead is actually touching the connector. You may need to straighten a thin paperclip or stick a needle in there to make it easier.
