no dash panel lights.
Old Aug 29, 2007 | 10:37 PM
anton17
Default no dash panel lights.
Hi,
I have a 1999 accord v6 sedan and I just installed a new stereo, after which none of the lights for my dash, guages, or rear tail lights come on. I checked the fuses and everything seems to be in order. I even tried plugging the old radio in and still all the lights didnt work. Anyone have any suggestions or ideas?
thank you
anton
Old Aug 30, 2007 | 12:54 PM
smaglik's Avatar
Default RE: no dash panel lights.
Did you pull on anything too hard when you were doing the install?
Old Aug 30, 2007 | 02:00 PM
anton17
Not that i remember of the top of my head, but anything is possible.
Old Aug 30, 2007 | 04:03 PM
finch13's Avatar
Did you disconnect the battery when you installed the radio. You might have blown a fuse.
Old Aug 30, 2007 | 04:33 PM
anton17
I have checked all the fuses, they are fine.
Old Aug 30, 2007 | 04:52 PM
sir_nasty's Avatar
I believe there is an under-hood fuse box for that car as well.... did you check those? I seem to recall there being a fuse under the hood that pertains to both the tail lights and the dash.... If you have checked all of those as well then it's time to find a wiring diagram.
Old Aug 30, 2007 | 06:02 PM
deserthonda's Avatar
ORIGINAL: anton17
pass side fuse box / as well fuse # 10 , 10 amps ??
ekg98
Dec 20, 2013 10:20 AM
naimperez
Oct 2, 2011 07:01 PM
marky4
Sep 7, 2006 01:25 AM
