No power to fuel pump
Old Jan 3, 2022 | 10:07 AM
Allen's Avatar
Default No power to fuel pump
I am in need of some help!
I have a 96’ Honda Accord, I got the car after sitting for a little over a year, the previous owner said the fuel pump was bad. So I replaced the fuel pump. Car started and ran fine! Then next morning all it would do is turn over, I messed with it, check the fuses. all good and still nothing! Then it started and ran fine for the day, then quit agains. I did some checking and found it was getting Intermitting power to the fuel pump, but once started it would run fine. So I replaced the main fuel pump relay. At First nothing change, but playing with it I got it to start, drove it home and now it won’t start. There is no power to the fuel pump now and all fuses are good. I know the file pump still works cause removed and tested it.I had a mechanic tell me about a main relay other than the main fuel relay, but I’m unsure on where it is or if that should be my next step to check. Also I know the wire from the fuel panel to the pump is good. Thank In advance!
Old Jan 3, 2022 | 06:02 PM
Are you using a volt meter or test light to test for power at the fuel pump? How are you connecting the meter to test (like where and which wire is being used for + and what wire or area are you using for your -)?
ghostpilot
Jul 3, 2013 06:57 PM
R.Weed93
Jun 1, 2012 05:58 AM
hondabuyer
Sep 17, 2009 10:12 AM
Jmoney
Aug 4, 2009 06:38 AM
HondaAccord93
Mar 18, 2009 08:40 PM
