No start
I am trying to help a friend , he has a 2008 Honda Accord, he has had a valve out of phase code for a while when it was still running I checked the sensors they seemed to read okay, I then checked the valve timing, not having a book on the car brought it up on top dead center # 1 & I think on the correct marks the valve timing is off by about 1&1/2 teeth, so it was also low on oil serviced the oil up , been busy with other , stuff so we hadn’t had a chance to change the chain etc.!
So about a month or so later they broke a drive axle, replaced both & when he started it up it was real low on oil like two quarts, so I suggested he go to a higher viscosity oil & after having the oil changed he drove to a couple places, then shut it down , now it won’t start!
Has fuel pressure 45 psi, it seems like it almost wants to start, I squirted a little fuel into the intake & it tries so it has spark?
08HondaAccord
Apr 9, 2019 03:06 PM
