no vtec ??
Old May 5, 2009 | 07:12 PM
wvballplayer8's Avatar
Originally Posted by PAhonda
If that coolant temperature sensor (2-wire) was messed up, then your check engine light should have come on.
You may want to stop by an autozone and have them read the codes. They will be P####. That will help identify any other problems.
Originally Posted by JimBlake
VTEC spool valve is on the backside of the head, near the distributor end. Look for a cylindrical solenoid, with a triangle flange (3-bolts). Don't un-do that flange, instead un-bolt the whole thing from the head. There's a gasket with a screen that can get full of crud. Get a new gasket since it gets hardened with heat & age.
yea i forgot to mention the check engine light is def out bc it doesnt come on when i first turn it on........ im gonna go to my buddies shop he has like a 1500 $ scanner and hes ordering me that new sensor so that should be done tomorrow............ ok im gonna try to check that spool out tonight but might have to tomorrow... ill keep ya posted.. thanks alot
trukid21
May 4, 2012 02:44 PM
PTVDesign
Oct 28, 2008 09:20 PM
FarRockAccord
18
Feb 1, 2008 06:36 PM
94coupeaccord
Feb 7, 2007 05:01 AM
