Noise after replacing upper control arm/ball joint??
Old Apr 28, 2014 | 08:30 AM
rmarrion's Avatar
Default Noise after replacing upper control arm/ball joint??
Hello,
I recently replaced the upper control arm/ball joint assembly on my 2001 accord. Everything went back together fine, but driving to work this morning it started making a constant thumping noise, during each rotation of the tire. Any ideas on what this could be? I don't want to keep driving it if there is a worse problem.
Thanks
Old Apr 28, 2014 | 06:45 PM
This was not there before the "work"?
Suggest you get the front back in the air and spin the tires - did the brake dust shield get bent during the work?
Old Apr 28, 2014 | 08:24 PM
jkowtko's Avatar
Almost A Senior Member
Does the noise go away when you apply the brakes? If so, then one of the springs on the brake pads could be out and the pad is knocking around a bit. Had this problem on a friend's VW golf.
If not the above, then let us know if the noise is different when turning one way or the other vs straight, and if going in reverse vs forward. Also at what speeds?
Old Apr 29, 2014 | 11:25 AM
Thumping as the wheel rotates makes me think of something wrong with the tire. Tread separating, or a bent rim, or something like that.
That would be an interesting coincidence for it to happen when you replaced the upper control arms, but you do need to rule out a damaged tire or wheel. Swap wheels front to rear & see if it changes??
Old Apr 29, 2014 | 06:05 PM
rmarrion's Avatar
Noise is occurring 20-30 mph, and usually happens when decelerating (not braking, just letting off the gas). I'll try rotating tires, would doing this work take that wheel out of alignment?
Old Apr 29, 2014 | 10:25 PM
Did you get the wheel tightened properly?
The upper control arm pivots from where it is bolted through the bushings. How did you tighten them? I typically put my jack under the lower control arm and jack up the suspension until the car just lifts off of the jack stand. That is close to the resting position of the car. Also check that you didn't leave a loose bolt. Did you pull out the spring/dampener assembly?
Old Apr 30, 2014 | 09:50 AM
rmarrion's Avatar
UPDATE: here is a video of the noise-
The wheel is tightened properly, and if I understand correctly, doing this work does not take the car out of alignment. The bolts for the bushings were hand tightened, but rechecked after a drive. I did pull out the assembly when I was doing this.
Old Apr 30, 2014 | 05:04 PM
rmarrion's Avatar
Problem solved, took some tightening... Stupid on my
Part.
Thanks for the help
Old Apr 30, 2014 | 06:34 PM
holmesnmanny's Avatar
What did you tighten ?
JohnNH
Nov 29, 2013 06:10 AM
thesoymilk
May 27, 2013 12:39 PM
honda1996
Sep 12, 2008 02:47 PM
PJ_STYLES_95AccordEx
Sep 13, 2007 12:12 PM
Hoang_Nguyen
May 13, 2007 10:13 AM
