noise while turning and vibration
Old Feb 10, 2008 | 09:12 PM
manu_b's Avatar
Default noise while turning and vibration
I had pervious post regarding noise coming from tyre while tuning( for few km)only when its cold outside. i went to hond dealer he said it could be bearing making noise. is it possible that bearing give problem at 101k? i also had problem of vibration when radiator fan kicks in. i found that its now regular it only vibrates some time really bad(could see dash vibrating). i dont now if its rpm or something else like engine mount? but i once saw it doing 650 rpm at idle in drive. but it mostly do 700 rpm when i turn on defogger. Can you guys advise me what to get checked as dealer charge a lot if you just tell them to check front end. how to you check front engine mount?
________
Mercedes-Benz Museum
Old Feb 11, 2008 | 01:06 PM
sir_nasty's Avatar
Default RE: noise while turning and vibration
to check an engine mount you're basically just looking for either loose nuts/bolts on them, or cracked/worn rubber... Sounds more like an idle issue, when you turn on the A/C does the idle drop drastically? When the car is sitting at a stop in neutral what does it idle at?
Old Feb 11, 2008 | 08:07 PM
manu_b's Avatar
Today it was vibrating but idle was at 750 rpm it stays here in gear or in neutral. my goes nearly at 10 km/h without having to press accelerator. i think its little fast i dont know if its like that in all accords. also i had two new engine mounts rear and driver side. they were broken before i bought it. could there be some thing misaligned in engine which cause this vibration.
________
Huge **** Webcam
Snowsurfer
Nov 25, 2014 05:46 AM
sona1111
Mar 10, 2014 02:38 PM
huhdo
Aug 30, 2012 09:06 PM
jumped_it
Oct 28, 2009 09:10 PM
farango
Feb 11, 2008 08:12 PM
