O2 Sensors and Cat Converter
Old Jun 7, 2011 | 09:38 AM
kenarrington's Avatar
Cool O2 Sensors and Cat Converter
I have a 2003 Accord V6. Got an O2 downstream sensor malfunction and replaced it. Now I'm getting a P0420 code - catalyst efficiency below threshold (Bank 1). I was told that the ECM needed to be reflashed to read the new O2 sensor. Is someone pulling my leg?
Thanks
Old Jun 7, 2011 | 10:58 AM
The ECM does not need to be reflashed to read the new O2 sensor. P0420 is usually the catalytic converter or an exhaust leak. If the car didn't have this code prior to the oxygen sensor code, then I would first check for an exhaust leak.
Although this is probably not your case, if the Accord was a hybrid; IIRC, there was a Honda technical service bulletin (tsb) regarding updating the ECM software for P0420.
snntuson
Jun 20, 2013 06:02 PM
rykertest
Mar 5, 2012 09:29 AM
brownguy04
Sep 15, 2007 01:31 PM
davidjata
Apr 7, 2006 07:31 PM
#1hondaaccord
Oct 3, 2005 09:31 AM
