Which oil filter?
Changing my oil tomorrow (first time, woohoo)
Anyway which filter should I use. The AutoZone here carries Bosch, Stp, Fram, Fram tough guard, mobil, K&N. The mobil and K&N are too expensive for me so what about the others? Or should I go to the honda service center and buy from them? Also will I need to replace the washer or not? For oil I planned on getting the Mobil 5000 |
I usually run Honda or Mobil. I would think a Honda one would be just as much as a mobil or K&N. Out of the cheaper ones I would go with Bosch, stay away from fram at all costs.
(Post 162439)
Purolator PureOne is really good too. Often good prices at Amazon, of all places...
Welcome to the forum!
Ditto Bosch/Puralator/Mobil...and NO FRAM!!! Do a forum thread search for oil filters, you will get plenty of info. Here's a good article: http://www.ntpog.org/reviews/filters/old_filters.shtml P.S. If you plan on posting alot, add your vehicle info in your signature...it helps alot. --Bigdawg |
$14 for a Mobil1?!?!? I pay $10-11 for those...
WTF man...
I got all the stuff I needed for the oil change and I couldn't do it. I put the jack in the middle under the engine on the frame part of the car and jack it to the highest the jack will go and it's not high enough to put the jack stands under on those spots by the wheels. I tried putting them on the frame on opposite sides of the jack but then it wasn't high enough for me to do anything. I could reach the drain plug but no way I was going to reach the filter. I'm pissed man, wtf. Should I just drive onto a high curb and try to change the oil like that? I don't want to waste the stuff... |
On the K-engine, I find it easier to reach the filter from the top. Remove 1 bolt bracket for the P/S hose on the corner of the valve cover. Reach down behind there to remove the filter.
Hey I dont know if anyone has an Advance Auto Parts Store near them but they are having a pretty good sale:
5qts. of Castrol Full Synthetic + K&N Oil Filter for $25 bucks or 5 Castrol GTX Conventional + FRAM Filter for $15 thought i'd pass this along.... |
Originally Posted by JimBlake
(Post 162767)
