Oil found in Spark Plug Holes
Old May 9, 2007 | 05:53 PM
dvanvught's Avatar
Default Oil found in Spark Plug Holes
I was checking my spark plugs today and when I pulled the plug wire off, I found that the spark plug was almost completely submerged in oil. I pulled out the plugs and checked them all and they looked ok so I put them back in. I then proceeded to run the car. When I started the car it smoked like a***** for about 2 min.......WOO HOO!!! No more bugs after that! Anyway I was wondering if anyone knows where the oil is coming from. Please don't say the head gasket is gone. I think the valve cover gasket was replaced already but not sure.
Old May 9, 2007 | 06:16 PM
sir_nasty's Avatar
Default RE: Oil found in Spark Plug Holes
go to our DIY section and read the Oil in spark plug tubes, there is a full writeup on what it is and how to fix it.... just a few simple O-rings...
Old May 9, 2007 | 06:23 PM
dvanvught's Avatar
Thanks....I had a feeling I was posting in the wrong place.....I tried to do a search on oil in the tubes but the search returned nothing.......Thanks
Old May 9, 2007 | 06:41 PM
sir_nasty's Avatar
No problem.... at least it isn't a major issue! Let us know if you can't locate the post for some reason....
Old May 10, 2007 | 02:54 PM
dvanvught's Avatar
Thanks...I fixed that leak but I think there is still one more leak. It looks like there is oil seeping from the oil pan gasket. I've washed down the engine a number of times now and i'm still finding oil dripping off the bottom of the oil pan. I cant see any oil running down the engine anywhere and it does look a little wet around the pan gasket. Is there any way I can repair this leak without having to remove the exhaust etc?
Old May 10, 2007 | 08:44 PM
I have found the pan bolts loose and one bolt missing on Accords on two occasions. Tightening to spec seem to help.
Old May 12, 2007 | 06:46 PM
dvanvught's Avatar
Thanks....I checked the pan and all the bolts are there but I'll snug em up a little if they need it. I really dont want to have to take the pan off. It looks to be a pretty big job and my exhaust is pretty rusty so I dont want to disturb it and then end up having to replace it all at the same time. I probably should replace it but if it aint broke I aint fixin it!!!
Old May 12, 2007 | 10:15 PM
smaglik's Avatar
I second tightening the oil pan bolts. On my 94 Accord once I had oil dripping off the bottom, and tightening the oil pan bolts stopped it.
Old May 19, 2007 | 06:27 PM
dvanvught's Avatar
tried tightening the pan bolts but I think my oil pan is rusted through!!! It's still leaking and it looks like it's coming from the bottom of the pan directly above the 2 exhaust pipes that come down from the manifold. Can I change the oil pan without dismantling the exhaust? Can I just slip it out of there? I can access all the bolts without moving the exhaust.
Old May 20, 2007 | 08:52 AM
deserthonda's Avatar
,, you need to remove the frt pipe to remove the oil pan .get a torch and heat up the exh bolts/nuts before you remove them .. this way they won;t brake
