Oil on spark plug
Old Oct 17, 2007 | 09:33 AM
DZL1's Avatar
Default Oil on spark plug
I have oil on one of my spark plugs. Its not on the actual part that sparks. Its on the threaded part of the plug. I was wondering if anybody had any ideas as to what that could be. Any help is appreciated.
DZL1.
Old Oct 17, 2007 | 09:37 AM
deserthonda's Avatar
Default RE: Oil on spark plug
go to our DIY section ,there is a write up on it
Please input year and model . If you need further assistance
Old Oct 17, 2007 | 09:43 AM
00AccordLX5spd's Avatar
Registered User
ORIGINAL: deserthonda
x2. You need to replace your spark plug tube seals. Go to the DIY section or use the search function above. I'm feeling nice this morning so I'll give you a link. This was found via the bottom post on the first page of the DIY section: http://filtsai.com/accord/valve_cover_gasket/index.php
Old Oct 17, 2007 | 11:16 AM
rickyh22's Avatar
Yea... Its the spark plug seal. Just go and purchase the whole package with valve seals it should come with it.
Old Oct 17, 2007 | 02:18 PM
falkore24's Avatar
ORIGINAL: 00AccordLX5spd
Spoon feeder!!!
Old Oct 17, 2007 | 02:48 PM
Registered User
Post *****!!
Old Oct 17, 2007 | 02:49 PM
finch13's Avatar
Since it's not really an extremely urgent fix, research prices online first and buy them there. If you get them at a parts store you'll pay an arm and a leg. I dropped one of the seals into engine bay abyss and ended up paying between $10 and $20 for just one set.
Old Oct 17, 2007 | 08:52 PM
brayner's Avatar
it's all in the DIY section - you have a bad valve cover gasket - everyone should input the make and model in their signature (and turn on the sig feature)
Old Oct 18, 2007 | 12:11 AM
ORIGINAL: brayner
It is not a bad valve cover gasket. .. v.c.gasket leaking will not get oil in the spark plug tubes,,
it is the upper spark plug seals that are leaking located in the underneath of the valve cover ,, or the lower rocker arm seals ..
Old Oct 18, 2007 | 08:05 AM
DZL1's Avatar
Thank you very much. Thats exactly the info i needed!!
DZL1.
