Oil Suggestions?
Old Oct 3, 2006 | 12:07 AM
  #31
Tony1M's Avatar
Default RE: Oil Suggestions?
ORIGINAL: deserthonda
ORIGINAL: WhyNotFab
I live in Florida btw, I read the DIY deserthonda posted and he suggested Mobil 1 Synthetic, 10w-10.
I guess I'd probably go with that
i got to read that but if i suggested 10w-10 than i misspelled it,,,,,,,,,,if you have the money to use syntetic than use mobil 1 ,, since you reside in florida i'd use 5w-30 or 10w-30
if you do not have the money for syntetic than use any major brands 10w-30 or 5w-30
Ditto on Mobil 1. There's been nothing but Mobil 1 since day 1 in our 92 and it runs as good as day 1, too.
Old Oct 3, 2006 | 03:36 AM
  #32
Hey Tex..you and I are old enouf to remember useing good old bulk oil in a clear glass bottle..arent we...[sm=happybounce.gif]...sure worked fine back then...
Old Oct 3, 2006 | 12:35 PM
  #33
RTexasF's Avatar
Super Member
Yep, 'fraid so. Didn't know what the hell it was.....just oil. How things have changed!!!!!!
Old Oct 4, 2006 | 12:38 PM
  #34
drummer1279's Avatar
well I found tranny fluid of all places on Ebay shipping and everything im paying $20.50 for 4 quarts.
Old Oct 4, 2006 | 12:40 PM
  #35
RTexasF's Avatar
Super Member
Honda fluid? That's a good deal.....whoda thought?
Old Oct 4, 2006 | 06:29 PM
  #36
deserthonda's Avatar
ORIGINAL: drummer1279
you can get it at the dealer for almost the same price,,,,,,,,and you only need 3 qts of tranny fluid ATF-Z1 $ 5.48 qt
Old Oct 5, 2006 | 12:29 AM
  #37
thanks desert lol..they are already on their way, but noted for future reference, and btw it is Z-1 that i am getting. 3 quarts? the last time I changed my tranny oil it only held 2.5
Old Oct 5, 2006 | 04:06 AM
  #38
put 2.5 qts,, start the car, go through the gears, turn car off and recheck fluid level .. add if needed... make sure that car is on level ground ..
Old Oct 5, 2006 | 10:23 PM
  #39
ok I have another question desert..can I loosen my trans cooling lines, drain the fluid all out and completely refill the tranny with new fluid? and if I can whats the total capacity of the tranny torque converter and all
Old Oct 6, 2006 | 01:32 AM
  #40
you can disconnect the cooler line to drain more fluid but you got to have the engine running and it still might not drain completely but it will drain a lot more than just normal draining
as for the capacity i need to know year and model
Here we go again
INPUT IT IN YOUR SIGNATURE
