Oil Under Hood
Old Nov 29, 2006 | 07:06 PM
daddy's Avatar
Default Oil Under Hood
94' Accord Lx - Manual
Today when I raised my hood to fill my clutch fluid up, I noticed oil on the inside of the hood. If the hood were closed it would line up directly with the timing belt area. Would this be an indicater of a leaky valve cover gasket or more serious? The car runs great and I have no motor trouble at all.
peace out,
daddy
Old Nov 29, 2006 | 07:15 PM
deserthonda's Avatar
Default RE: Oil Under Hood
TAKE A CLOSE LOOK AT THE P/S PUMP I BET THE FRT SEAL IS LEAKING
oops caps..........put your finger under the p/s pump pulley CAR OFF OF COURSE .. if it is oil wet frt seal is leaking .. need to reseal pump.......
Do not let someone tell you to replace the pump,, Honda sells a reseal kit 15-20 dolars , the rest is labor ,, 1.0-1.5 hrs
Old Nov 30, 2006 | 03:37 PM
daddy's Avatar
Thank you sir...I will give it a look over :-)
peace out,
daddy
Lovemy97HondaAccord
Mar 5, 2014 06:04 PM
MessAround
May 24, 2013 08:42 PM
Pickrng
Jun 22, 2010 12:54 PM
dtycoon2003
Aug 11, 2006 08:29 PM
boo623
Jul 9, 2005 07:30 PM
