Oil in Vacuum Line
Old Sep 25, 2012 | 10:30 AM
Drpepper's Avatar
Default Oil in Vacuum Line
Is it normal to see motor oil in the vacuum lines of a 2005 Honda Accord 2.4L Manual Transmission? Aside from a mildly rough idle when under load (A/C on), the car does not seem to have performance problems.
I noticed oil residue inside the vacuum line coming from the top of the intake manifold and routed to the AC pump. I haven't inspected any of the other lines yet.
Thanks.
Old Sep 25, 2012 | 11:42 AM
There should be a PCV line for the PCV system that runs from intake manifold to engine crankcase. PCV valve will be at valve cover or intake manifold end.
Another line runs from valve cover to air intake duct to allow filtered air to enter the crankcase.
Oil in the PCV line is not unusual as crankcase vapor w/ oil is being pulled from crankcase into intake manifold.
cukaracha
Jul 17, 2014 04:05 PM
Pattywagon
Jan 24, 2012 07:05 PM
swiftymorgan
May 30, 2010 03:59 PM
ohanahorse
Sep 28, 2009 08:49 AM
ohanahorse
Sep 15, 2009 10:38 AM
