Old wood creaking noise on bumps?
I took a couple videos of my 97 accord. I just started to hear this old wood creaking noise, I think it's coming from the front suspension but not very sure.
The first video, about 3 seconds long, is the car turned off, and my pressing down on the car. http://www.4shared.com/video/SPewnoXzba/IMG_8331.html The second video, about 20 seconds, is the car going over a couple of speed bumps. http://www.4shared.com/video/5sGSg1giba/IMG_8334.html You may need to turn the volume all the way up. Anyone know what this is? I tried to grease up some bushings in the front but I still hear it. |
If you can produce the sound by bouncing on front end, try searching for source by touch w/ someone else providing bounce to front end. You should be able to locate the noise source. Feel upper and lower ball jts, tie-rod BJ's (outer and inner by feel tie-rod arm). Check anti-sway bar bushings and end link stack for same noise. good luck |
I couldn't find anyone to help me push down while I look, so I took it in to a shop.
The shop said all the bushings need to be cleaned and lubed, and/or replaced. But this shop can't do anything because my car has aftermarket suspension (it is lowered with coilovers) I got a quote from another shop that will replace the following bushings... control arm bushing - front control arm bushing - rear sway bar bushings Am I missing any more bushings? The shop with the quote told me 'control arm' but do the upper and lower control arms have different bushings? |
I have the same noise coming from my 94 on Neuspeed springs. It's been doing it for... idk a year and a half? Dry park test seems to be showing no play in any of my bushings or ball joints, so probably just needs greasing. Are they the same bushings that were on the car before you changed suspension?
Originally Posted by kayweb
(Post 348365)
Yeah it's the same OEM bushings. Car currently has 137,000 miles. Coilovers were installed at about 129,000 miles. I just had a friend spray WD-40 and it seems to have done the trick for now. But I'm sure the noise will come again. |
Originally Posted by mr97accord
(Post 348385)
