Outside Temperature Gauge
Old Jan 30, 2007 | 07:05 PM
mdubb99
Default Outside Temperature Gauge
I have a 2003 Accord. I recently replaced the factory radio with and aftermarket using the Metra fit kit. I noticed that my outside temperature gague no longer works. Does anyone know of a corelation between the factory radio and the temp gauge? I also used a steering wheel control interface piece. Can the gauge be reset? I appreciate any help!
Old Jan 30, 2007 | 07:08 PM
sir_nasty's Avatar
Default RE: Outside Temperature Gauge
unless the radio displayed the outside temp I know of no correlation between it and the temp sensor... is the sensor reading anything at all or is it just dead?
Old Jan 30, 2007 | 07:09 PM
mdubb99
No. The display is in the gauge cluster above the steering wheel. The readout is blank.
Old Jan 30, 2007 | 07:54 PM
sir_nasty's Avatar
one way to reset the guage is to pull the main fuse or remove the negative battery cable for a few seconds.... if you were messing with the steering wheel it's possible that the connection to the readout popped off...
lks
Apr 26, 2012 04:52 PM
budedm
Jan 30, 2012 01:44 PM
thamora3
Jan 13, 2012 11:09 AM
Asw19flier
Sep 12, 2010 10:03 PM
Karthigan
Nov 27, 2006 02:55 PM
