Help needed: Passenger door wont open.
Old Jan 30, 2007 | 07:36 PM
smoothoperator
Default Help needed: Passenger door wont open.
2001 4 door accord v6
two weeks ago my passenger door became jammed somehow (no physical damage or internal electrical problems (that i know of)) and i haven't been able to open it. the lock is stuck in the locked position and wont budge no matter how hard i try. using the key doesn't work either. when i unlock the doors using the button, the passenger door's lock shifts up and down a very negligable amount, but nothing else happens.
i thought about checking the fuse box to see if anything was blown, but that requires opening the passenger door (very intuitive...yeah right).
any help would be GREATLY appreciated!
thanks.
Old Jan 30, 2007 | 08:02 PM
sir_nasty's Avatar
Default RE: Help needed: Passenger door wont open.
if the door lock moves a slight amount and then back I'd imagine the fuse is fine, and even if it was a blown fuse the key should work or you should be able to unlock it from the inside.... if all of those options have failed it sounds like it's either jammed really good or perhaps the actuator messed up, have someone from the outside of the car press the door in and try to unlock it, if that doesn't work try unlocking the door as you are pulling the door handle to open it... if that still doesn't work then you could be on to some major pain in the rear issues....
Old Jan 30, 2007 | 09:00 PM
smoothoperator
i'll give those a try...hopefully this will work though i sincerely doubt it. god, the last thing i want to do is bring my car into the incompetance that is my local Honda Motors fix-up palce.
bds85466
Jan 19, 2014 05:19 AM
jerzeegirl70
Jul 22, 2012 11:44 AM
baitshopboy
May 23, 2012 07:08 PM
MrGmo
Sep 28, 2007 01:40 AM
