overhead light while turning right
Old Dec 30, 2009 | 05:11 PM
lairdylairdy's Avatar
Default overhead light while turning right
hey, so my overhead light turns on when i'm turning right (no matter how quickly i am turning), and every now and then when i'm having to slow down at a relatively quick rate
i know it has to do with the driver door being pushed out slightly from the force of the turn or whatever, but i was wondering if anybody here might have any other ideas on the best way to take care of the problem
thanks!
Old Dec 30, 2009 | 11:20 PM
kris_loehr's Avatar
Do the doors close even with the body? I would think the light for the door on the dash would be lit also if this was the problem.
Old Dec 31, 2009 | 12:39 AM
Lightbulb
Tape the door button closed with good sticky duct tape...
Old Dec 31, 2009 | 10:32 AM
yeah, the door closes flush with the body. and the light on the dash does indicate the door as being open when i turn, that's how i know it's that door
taping the door button closed would work, lol, but i'd rather find a way to make it function like it's supposed to =P thanks though
Old Dec 31, 2009 | 01:00 PM
mcnoople's Avatar
Swap the switch from one door to another. If the problem moves with the switch then replace the switch.
Old Dec 31, 2009 | 01:06 PM
good idea...thanks
Old Jan 4, 2010 | 07:47 AM
Go to hardware store & look for adhesive rubber bumper blocks, like you'd put on table legs to keep them from slipping on the floor. I've seen these silicone rubber disks about 1/8-inch thick that would work for that. Stick it on the door right where it hits the switch, so it presses the switch in a bit more.
Old Jan 4, 2010 | 10:53 AM
that's actually what i ended up deciding to do. another friend suggested it too and it's so simple, haha
thanks for y'all's help!
Old Jan 4, 2010 | 11:53 AM
Did it work?
Another possibility is a bare wire rattling around in there. The pushbutton switch closes the circuit to ground, so any bare wire hitting metal will do the same thing (& light up the warning). If that's it, you'll have to find it & fix it.
Old Jan 4, 2010 | 01:44 PM
well i haven't tried it yet, but once i try it and see if it worked, i'll check the wiring
thanks for the heads up though
