Overheated and now d4 flashes
Old Apr 14, 2014 | 11:34 AM
jrock24's Avatar
Default Overheated and now d4 flashes
So last week my car overheated. I thought it was the radiator or the fan, but the fan was working fine. So I replaced the radiator, and still had a leak. It ended up being the heater core hose that is under the dizzy. So I replaced that and now it doesn't leak any more. During the radiator removal, I lost some fluid. Not a whole lot but when I disconnected the cooler lines some ran out. I have checked my trans dip stick and the fluid level is fine.
This morning I drove to work (first time since I finished and confirmed no leaks) and the d4 light started flashing and first gear was not as peppy as it was before.
Can the loss of maybe a (probably less) quart of fluid make the d4 flash?
Old Apr 14, 2014 | 11:35 AM
jrock24's Avatar
I forgot to mention the hose blew coolant all over the engine, and I had to remove the dizzy to get the hose off. The blades didn't move and it slid right back in without a problem.
Old Apr 14, 2014 | 12:10 PM
D4 light flashing means a trans code is stored in TCM. See DIY forum for obd1 code check procedure and extract code.
I don't see how replacing radiator replacement could affect trans unless somehow ATF flow to radiator was blocked (pinched hose, debris).
Old Apr 14, 2014 | 12:15 PM
jrock24's Avatar
What about the loss of fluid and the dip stick showing it is at the proper level?
Old Apr 14, 2014 | 12:33 PM
Fluid level might be OK, but if fluid path is blocked, it could cause trans problems.
Old Apr 14, 2014 | 05:53 PM
jrock24's Avatar
If the hose was pinched enough to throw a code, do you think it would be shifting normally?
Old Apr 14, 2014 | 07:21 PM
Just check the codes like mentioned before and then start troubleshooting.
Old Apr 15, 2014 | 09:20 AM
Fluid loss from disconnecting the ATF cooler lines means I would expect you should need to add some ATF to replenish the loss. But that all comes back to the level on the transmission dipstick. If the dipstick shows the proper level, then you're OK.
Could there be air pockets in the ATF lines or in the radiator (ATF tubing)? So the level looked OK when you checked it, but then the level dropped after you began driving? (Just trying to rule out some obvious stuff)
Old Apr 15, 2014 | 03:49 PM
jrock24's Avatar
I tried searching the DIY section but cannot find the procedure for check the codes. I BEG you guys for a link. Thanks
Old Apr 15, 2014 | 04:32 PM
