Overturn
Old Apr 11, 2013 | 10:38 AM
rwyatt80's Avatar
Default Overturn
Hello!
I own a 96 accord lx 4cyl and I have been having issues with what I think is the starter. You see, When I crank my vehicle up, it sounds fine somedays. Other days, it sounds as if I am overturning. I apply just enough pressure to turn the key. I have had the starter replaced twice in less than two years because I was told this was the culprit. Could the problem be that the starters are aftermarket and not OEM???
Any help is greatly appreciated!!
Old Apr 11, 2013 | 12:17 PM
UhOh's Avatar
Originally Posted by rwyatt80
...overturning. I apply just enough pressure to turn the key.
I don't know the term 'overturning' ... can't help there.
Did your component came from Autozone or Oreilly's? ... been there, done that.
Now I buy @ NAPA or dealer - and these work and last.
Old Apr 11, 2013 | 02:51 PM
rwyatt80's Avatar
My apologies. To overturn is when you turn your key to start your vehicle. Instead of letting go, you hold on to the key, which creates a screeching noise, thats overturning. Ill look into getting an OEM starter. I will also check NAPA. Thanks!!
Old Apr 11, 2013 | 03:38 PM
Roader's Avatar
It could well be a crappy aftermarket starter but take a look at the ring gear before putting on a new starter. Check the entire circumference for bad teeth.
Old Apr 30, 2013 | 03:49 PM
rwyatt80's Avatar
I went to NAPA to get a starter, so far so good. The mechanic said that the reason for the noise was the bendix (if i spelled that correctly) was slow to respond and did not come all the way out when pressed out by the solenoid. I am hoping the third time is a charm. They did tell me that the NAPA starter didnt respond the first two times after installation. It was tapped...after that, no problems. I hope that the issue can be attributed to it being on the shelf...if not...back to the drawing board. Thanks for the advice!!
